You're welcome.
I recommend that you don't replace micas in tuner or IF stages unless you know for a fact the cap your changing has failed. The tuner/IF sections are much gentler on the micas, and they almost never fail in those circuits. Also if you change mica caps in the tuner/IF stages you will likely need to realign the set.... TV alignment requires a lot of specialized, costly, complicated, accurate equipment and skill/practice, and is something you want to avoid.
