Good to know super glue will hold that type of plastic. When I did it for a living and charged customers money, and had to guarantee the repair, I never tried gluing a gear. But nowadays you have to improvise.
I did have a few Sonys that developed a loose pressed-on worm gear on the load motor shaft and rather than have an estimate declined to replace a very expensive assembly, I would take the motor out, file a flat spot on the motor shaft, degrease the pulley and shaft and apply a tiny bit of JB Weld. I knew that sucker ain't spinning on the shaft again!
