Old 03-10-2016, 01:37 PM
Olorin67 Olorin67 is offline
I have a voice of music amp that is push pull 6aq5 (same as 6v6) that is all powered from a EZ81,(6CA4). used it for years with the factory rectifier tube. Where you usually see a really big rectifier in a console like this, is if the power supply of the amp is also used to supply the tuner chassis as well. I suspect this one has a self powered tuner. I have a Motorola that uses a 3DG4. an I've seen a couple that even use 2 5u4's.
