Old 03-03-2016, 07:14 PM
The one is probably darker gray because it had a tinted faceplate, I've never heard of a tube changing color from use. The darker one will probably have better blacks and contrast.
I would just look at the socket, if it looks the same and the mounting is the same it'd be worth a shot to try it.
You may be able to Google the CRT numbers and find the specs and pinout to compare also.
