Old 02-12-2016, 07:22 AM
This set works so good it's like having an HD tv it's so sharp one would not believe it. These sets are known for flybacks it's well documented. Made in 1996 The first fly went bad 6 years later, second in 2008 replaced with RCA , third fly in 2011 replaced with after market only got 3 years , forth 2014 replaced with after market, fifth fly didn't last long went bad at the end of 2015 , now I replaced the sixth fly with RCA it's clear the RCA lasts longer since the RCA flys seem to last 6 years each. As for the original post with the problems I was having turned out to be the flyback it caused all kinds of symptoms which all went away after changing the fly. This set out performs any flat panel tv . Obviously after market flyback transformers just don't work as well as the original and in this case I should have learned from the second fly that they last longer and overall are better which the set was designed for. I will post a screen shot of this set you guys can determine what you think. And yes I must be Alittle nuts for holding onto and repairing this set for so many years for it truly works so well and as long as I can get an RCA fly and the crt stays good then why not.
