Assuming yours is a front-loader....There is a a tray the cassette rides in between the play position and ejected position. There will be plastic/metal guides/tracks on both sides of that tray. The tracks should have an L shaped slot in them that the tab/pin of the tray rides in as a guide....There is at least one on each side of the tray in most VCRs.
If you eventually decide you can't fix yours and want to part it out/get rid of it, post some pictures of the capstan motor....If it is the right one I'd be interested in buying it off you.....When I changed the cap my soldering iron melted a bit of the plastic tire on the capstan rotor.....That tire is essentially a loop of magnetic tape that is read by a tape head to make a speed feedback signal...It don't play quite right with a melt spot.
Well monkeying around with the Beta today I looked again to see if those tabs were maybe broken off (now knowing after reading your post what to look for) and they're still there intact, and its acting more and more like it might be a a motor issue than a mechanical issue, because now its doing in load mode now too whereas before it was just doing it in eject mode, so I'm wondering if maybe the drive motor for the eject/loading mechanism isn't maybe starting to go bad (like maybe the brushes are starting to wear to the point that the motor can't get up enough torque to drive the loading mechism anymore.) Last edited by Captainclock; 12-23-2015 at 10:46 AM. Reason: Added some photos |
