It went real well scraping, masking and coating it. I ended out scraping the whole thing clean. Now if the other parts would just arrive!
Success! I changed the electros, a reg cap and a resistor that were in areas I had to solder anyway, plus some tubes.
The bottom half is brighter than the top half (the picture was not moving when I took it). My brightness will go much higher when I turn that control. Volume sounds ok. I only ran it a couple minutes. Will start recapping, but how do I get rid of the 2 parts on the screen? (There is a curtain reflection on the top half) Also, can I safely pull the chassis back, laying it down, to get at the picture tube button hole to safely discharge it? Can anything on the chassis bite me when I do that? theres no other way to get at it as you can see. |
Congrats fixmeplease ! .. now you need to continue.. ( for a better result, i would change all caps and resistor ( paper and wax if the TV has them..)Even if some caps look like good , sooner or later they will ... POUFFFF !
