I don't know if ya read my story at the beginning of this thread, but this one was luck as well. I just happened to know exactly what it was, from a picture only showing the back. This set would probably be in the trash or grossly overpriced in some antique/junk shop if I didn't pick it up. That's a nice set you found, and for real cheap at an antique mall! Last antique tv I saw at an antique mall/shop was an abused Emerson table top from '53 that was overpriced at around $100!
![]() Welp, back to the Porta-color. Played my SNES on it for about 2-1/2 to 3 hour's this afternoon/evening. Ran good, but when hot, the picture shrunk a bit on the top and bottom. Had 1/4" black bars along the top and bottom. I don't know if I should worry about this or just not care. Also noticed, when paused the picture has a slight wavy flag effect. Should I worry about my e-caps because of this? I think i've read somewhere here that, that is a sign of faulty e-caps...
The other TV I got was a late 1980s 25" Sony Trinitron TV that was a stereo MTS enabled unit but only had one built in speaker and had a full set of AV jacks on the back and on screen display that I ended up giving to a friend of mine who used it until the the built in speaker went out and then he ended up throwing it out. And the other TV I got from my high school was another 25" Panasonic, this one being from around 1990 and it had on sceen programming and everying and its original remote and I ended up giving it to another friend of mine to use and they are still using it to this day. As for the Philco Townhouse its mostly up and running except needing to redo the aquadag coating on the back of the picture tube and replacing some capacitors in the vertical output/amplifier stage. |
