Old 10-06-2015, 04:50 PM
MRX37 MRX37 is offline
Okay I figured making a video wouldn't hurt, and might shed more light on what's wrong with this set.
http://www.youtube.com/watch?v=emRtk...ature=youtu.be
You may *barely* be able to see the video flicker on the screen as I change channels. Interestingly the image brightens a lot as it's being shut off. There's a noise like static electricity discharging coming from the flyback area, tried to capture it on camera.
I thought all the tubes were glowing. Not so sure now. Maybe i was imagining it.
Old 10-07-2015, 12:05 AM
My Silvertone roundy did that when it's boost diode was open....I still suspect the boost/screen system. I'll try to get my schematic out tomorrow so I can check your measurements against what the set should be doing.
Old 10-07-2015, 07:32 AM
I'd like to know where that boost diode is so I can pull it and check it.
Old 10-07-2015, 09:32 AM
Findm-Keepm's Avatar
Followin' the Rules...
Pointed out in an earlier post, but circled in green here.
That thing half cut off at the top center of the pic is probably the boost diode,
Brian
USN RET 22YRS (Avionics/Cal)
Old 10-07-2015, 10:03 AM
To me, with those black stripes It looks more like a barberpole resistor. Hafta see more of it to tell for sure.
Old 10-07-2015, 10:23 AM
Here's a better shot of it:
I clipped a lead and tested it. If it's the boost diode, it tests open both ways.
Old 10-07-2015, 10:43 AM
A video would help. Do it on youtube so everyone can
see it EASILY.
After the video try this:
Put all the G-2 ( screen) and the 2 drive controls to mid
range. Measure the CRT voltages.
Usual wires are solid colors, white /w tracer, yellow w/ tracer.
three of each.
DO NOT DO THE FOCUS its the black wire set apart.
Dont bother with the filament, twisted pair of brown.
Post results.
Old 10-07-2015, 10:45 AM
As it will - it's a high voltage selenium rectifier, and the forward voltage drop is beyond what a DMM/Ohmmeter/Diode check function can provide.
Only two ways to check - with the set on, measure the Boost (~900-1100V - more than a DMM can handle) with a VTVM =OR= replace the rectifier and run the set.
Brian
Old 10-07-2015, 11:37 AM
rca2000's Avatar
rca2000 rca2000 is offline
At SOME point...you MUST check that CRT. As much as we hate to admit it...sometimes they DO die.....and sylvania tubes seem to die quicker than most.
Hopefully...it is NOT the tube--but you DO need to know. I have had sets before...with tubes SO waek on all three guns...they just would NOT hardly light....till "pounded on" with a rejuvinator...
At least THEN...you will know. ANd if it is NOT the CRT...I would look for a near total loss of video drive and such....assuming all voltages for the CRT screens and such are ok.
Old 10-07-2015, 12:06 PM
see it EASILY.
three of each.
Post results.
You mean like the one I posted in this thread yesterday?
Not sure what else to make a video of.
Okay I set the screen controls to about mid way and I've measured all the wires on the CRT socket except for the black wire, and the brown ones.
White wire/blue stripe Over 500 volts
White wire with red (brown?) stripe 800+ (cut power at 866 volts)
Yellow wire with red stripe: Starts off at 350 volts, drops to around 330 when the set warms up.
Green wire: Starts off at 360 volts, drops to 180
Yellow wire with blue stripe: Starts off at around 335, drops to around 325
Dark blue wire (violet?) starts of at 330, drops to 170
Third yellow wire with dark stripe (not sure of stripe color): starts of at 350, drops to around 330.
and rca2000 I would love to check the CRT. Do you have a tester I can borrow?
Old 10-07-2015, 12:17 PM
rca2000's Avatar
Where are you? Liklely you are WAYYYYY too far away from me. I have a GREAT CRT tester--the sencore CR-70. If it can;t help your tube....NOTHING will !!
BUT...I live in SW Ohio... Where do YOU live?
I will BET...SOMEONE in your area DOES have a tester you could use though...
Old 10-07-2015, 12:23 PM
Near Detroit...
Old 10-07-2015, 12:25 PM
rca2000's Avatar
OK...others here will have to help me...but...
That 800+ volts tells me your B boost IS working ok. With that lrvel of voltsge...you SHOULD have enough screen voltage..
HOWEVER.....some OTHER voltages seemed HIGH to me. If you are getting over 300 volts to the CATHODES of the tube...it will likely be in CUTOFF... that is where I need help...not sure which leads go to the cathodes. But IF your cathodes are biased too much positive...there will NOT be much emission.
On a SS set with combined Y-C at the tube--...one could "force on" the cathode of a particular gun and then see if the tube would flare to retrace of that color. If it DID...and the raster was pretty bright of that color...it would usually rule out the CRT---for a symptom of no/low brightness..
But on a DELTA gun tube on a TUBE set...not really sure HOW one could do this. Perhaps someone else knows...
Old 10-07-2015, 12:28 PM
rca2000's Avatar
There are several guys up that way. Captain Moody for one. He likely has a tester.
Old 10-07-2015, 01:06 PM
What would happen if I messed with the CRT bias control? There's also a control mounted to the flyback cage, several inches above HV ADJ control. What's that do?
