Old 09-15-2015, 11:50 PM
Ok! Then there appears to be no bonded safety glass... The tension band over the clam-shell is indeed the only means of safety protection. I would not remove the t-band! Even if you did, I suspect that you might find that the ears are spot-welded to the clam-shell and you would have to cut them off anyway, which would be very hazardous with the tension removed.
Jr
