Old 08-08-2015, 03:57 PM
9-160 removal. Hope I remember everything ! Been years.
If the board has been out some things MAY have been
left out. Uses all 1/4 inch bolts.
Unplug set.
Put a clip lead on the CRT shield the other end to a thin
well insulated screwdriver. Put under HV lead & move around.
Remove HV lead.
Either a plastic or metal bracket goes from flyback to frame, remove.
Along the bottom is a plastic holder held with 1 bolt remove.
On top of board near 2 connectors is the key. Its red & sometimes
wrapped in tap Twist it 90 degrees & pull it out.
Rear edge connectors may have little black steaks. Remove & dispose.
Unsnap all edge connectors.
IIRC there are 4 to 5 top connectors, unplug.
Undo focus wires from FBT to CRT socket board. Its a flying connection.
Unplug ground wires from CRT shield & one from spark gap at
rear edge of board usually.
On either side of the PCB there are claws holding it in. Push
down on them & work the board out.
Be careful of the edge connectors you can smash them easily.
Sounds like a lot but after a few times you can R&R it in
less than 2mn. You CAN NOT put it back wrong, its got keys on
everything.
