Old 07-29-2015, 01:01 PM
dishdude's Avatar
dishdude dishdude is offline
Zenith flat CRT HDTV
I am on the lookout for one of these sets, and I am looking for some info on them. I believe they are one of the last sets made to have a Zenith chassis and Zenith design, is anyone familiar with them? I believe they are from around 2001-2003.
http://www.ebay.com/itm/Zenith-C27V2...item5b15f67c91
Old 07-29-2015, 01:41 PM
jbattles's Avatar
jbattles jbattles is offline
jbattles
I have that same set and I love it fantastic picture blows any set away and I love it.attachment5.jpg I don't know who made the tube but wow what a picture.
Old 07-29-2015, 02:48 PM
MRX37 MRX37 is offline
an HD set with a 4:3 aspect ratio?
Old 07-29-2015, 04:36 PM
lnx64's Avatar
lnx64 lnx64 is offline
Yes, some were like this. I have a Prima that's the same way too.
Old 07-29-2015, 04:46 PM
What resolution were those, higher than 480p?
Old 07-29-2015, 05:30 PM
Apparently 1080i... so 1440x1080?
Old 07-29-2015, 05:39 PM
lnx64's Avatar
It was still 1920x1080, it just resized the picture vertically by adjusting the v-size on it's own so no lines were lost.
Old 07-29-2015, 06:03 PM
I dont think this is a true Zenith chassis. The last flat
CRT Zenith sets we sold were made by Daewoo ! That
would have been just before this set. The latest real Zenith chassis is
probably in the consoles which were the last Zeniths we sold
( franchised 1958).
I never knew a Daewoo was under the hood til one came in for service
with a bad FBT. I almost crapped myself !
Anyhows Daewoo was an odd duck. If it had Daewoo brand on it
it was a POS. Any other brand on it even the same chassis was
a good set. Go figure
The Zenith /Daewoo gave a damn good pix, well built & well
featured.
Old 07-30-2015, 02:11 AM
Such sets were fairly common in the early days of HD displays. They were much less expensive than the 16:9 sets available in that era. None of them had built-in digital tuners that I am aware of. They typically went into "letterbox" 16:9 mode when switched to an HD input (component video or RGB/"VGA").
Most of them accepted a 1080i input via component or RGB; some also accepted 720p. The actual resolution is/was probably about 720p (1280x720), in the 16:9 area of the CRT.
Old 07-30-2015, 11:50 AM
I know that S0ny produced several 16:9 CRT HDTV sets... who else made 16:9 CRT sets? Wouldn't these be fairly collectable? Bet they weighed a ton.
Old 07-30-2015, 12:27 PM
Findm-Keepm's Avatar
Followin' the Rules...
The D line would do 1080i, but only from an external input. Circuitry and deflection was basically an LG Computer monitor, with an NTSC tuner and sound tacked in. I've only seen two - one with a cracked case (owner tried to carry it through a door on his shoulder) and one at a conference, unrelated to TVs. C line sets would do 1080i and VGA, to 800x600, IIRC, and yes, were not Zenith sets, but had Zenith labels for the three modules - power supply, main board, and CRT board. I have spec sheets for them in PDF here somewhere.
Cheers,
Brian
USN RET 22YRS (Avionics/Cal)
Old 07-30-2015, 03:08 PM
I've seen RCA and Toshiba 16X9 CRT sets....
Old 07-30-2015, 03:34 PM
jbattles's Avatar
jbattles
it looks like a zenith chassis when I looked inside trough the vent. its such a fantastic set I don't who made it. the set will only do 480i or 1080i through the vga input but makes a nice computer monitor.
Old 07-30-2015, 03:45 PM
Panasonic had their Tau series of 16:9 sets. I had a 30" one I got from Portsmouth (VA) City public schools for 25 bucks , but with the cable box output, I could never get anything other than letterboxed 1080i. It was like watching a small computer monitor. Panasonic had one Tau DVD player that worked with it, but other than that, no other accessories or ATSC tuners.
Brian
Old 07-30-2015, 03:56 PM
Samsung made 16:9 CRT sets at least until late 2003. I know because I found one and brought it home.
