Old 07-27-2015, 12:53 PM
Originally Posted by Chip Chester View Post
Many older sets will have those attributes, but I don't believe your antenna will see any tunable signals, unless those stations managed to keep low-power analog licenses for their original analog channels. Even then, the "low-power" side of the equation would be a deal-killer 30 miles out.
You could tune them with a converter box, or on your cable feed (if you have one) and re-modulate/distribute locally.
I believe there was a post here about 9 months ago about a Japan-market LCD tv with a physical tuning knob. Don't know if it was an actual product or just a design study.
Chip
Thank you for your reply and for the information on the Japanese-manufactured TV with standard tuners; however, I am looking for a Zenith or RCA set with such a tuning system. I had two Zenith color portables in the '80s, one of which was knob-tuned. They both had excellent pictures for their ages, but they were lost when I moved here 15 years ago. I should have kept the one with the standard tuners.
Why would any analog TV with an antenna not receive any of the local stations I've been watching as long as I can remember? Just because I live 30+ miles from the city of Cleveland (and perhaps 10-15 miles further from the TV stations' towers, which are all located in a southwestern suburb of the city) should not have any bearing on whether or not I would receive anything. Every one of Cleveland's television stations will reach at least 50 miles from the towers; channel 3, the NBC affiliate in Cleveland, for example, used to say in its sign-on announcement that its signal covers 17 counties in northeastern Ohio, and the other two (at the time) network affiliates could have made the same claim as well. I remember when folks living as far away as 75 miles from the stations could receive their signals with an antenna on a tower; in the '70s I knew someone in that area (Canton, Ohio, seventy miles southwest of Cleveland) who was getting all three network stations using just rabbit ears, and she was getting watchable pictures from all of them.
Why should DTV be any different? I've tried my flat-screen TV with an indoor DTV antenna, and was able to get every Cleveland TV station except channels 8 and 19. The reception is excellent, even at this distance. I'd be using an indoor antenna today if not for the fact that I do not receive the CBS affiliate on channel 19 with such an antenna. (Channel 8 is a Fox affiliate which I don't watch, so being unable to receive that station doesn't bother me.)
I believe all of DTV's reception problems in most if not all areas could be solved if the stations all had 300+-kW ERP signals, as they did before converting to digital. Channel 8, for instance, had a 312-kW ERP signal, and the other two were likely just as powerful. The ABC affiliate in Philadelphia recently applied for and was granted permission to increase its signal power, so as to improve its coverage area; why Cleveland's CBS affiliate, which had a 3.72-kW ERP analog signal, cannot do the same to eliminate the dead spots in its own coverage area is beyond me. Every viewer it loses because its DTV signal does not reach where the analog one did reach means lost advertising revenue, so it would be to its advantage to increase its DTV transmitter output to the maximum power allowed, which is five million watts ERP. The station's owner, Raycom Communications, already operates a translator station on channel 24; however, that one is for an area 60 miles southwest of here, too far away to be received at my location.
I also read somewhere that the CBS affiliate in Youngstown, Ohio on channel 27 is supposed to be a "fill-in" signal for areas that do not, for whatever reason, receive the Cleveland CBS affiliate; however, that doesn't work where I live--channel 27, or whatever DTV channel that station actually broadcasts on, is completely blank. I may look up channel 19 on Wikipedia and find out, once and for all, what its DTV coverage area is supposed to be.
I don't know if the FCC's ruling regarding "repacking" of the the remaining VHF and UHF TV stations in this country, which is expected to take effect next year some time, will have an effect on the problem of dead spots in DTV TV stations' coverage areas, but I will keep a close watch on the situation, waiting for news (if any) of actions that will eliminate these problems once and for all. Many TV viewers are using antennas again and are likely frustrated by not being able to receive every TV station in their areas just because those stations, often network affiliates as in my area, are lower power DTV ones.
