Old 07-19-2015, 11:44 AM
Originally Posted by init4fun View Post
To me , to be honest , I'd rather the sixth tube , if we're going from an AA5 to a six tube radio , be an additional IF amp stage rather than an RF amp . The additional IF stage would benefit selectivity but costs the extra IF transformer as well
Not necessarily, I have also seen a "cost effective" addition of an additional IF amp stage without adding another IF transformer, by simply RC coupling two tubes together between two transformers. IIRC, this trick was also used on some Philco models, causing some confusion as to the number of *actual* IF stages in the radio, similar to the confusion caused by adding a RF stage *without* using a 3 gang tuning capacitor. Check the schematics to be sure, especially on 40s-50s Philcos.
Old 07-19-2015, 09:11 PM
The first generation "hippo radios" used the same RF stage. The later ones used two IF stages instead and a 14AF7 osc mixer tube.
I have to consult the schematic again! I don't remember if it had another IF transformer. I know, a lot of companies didn't, just the RC coupling.
I have an Emerson that has four 6BJ6's, one for the osc, one for the mixer and two for the two IF's, RC coupled.
Old 07-19-2015, 10:30 PM
Bingo! One of my "hippos" has the RC coupled IF stage... two 7B7s with a 16K plate resistor on the first, then a 220 pf cap to the 150K grid resistor of the second. I have actually used a similar scheme once or twice when I could not find a suitable replacement IF transformer for one with an open primary or secondary. I thought that was pretty sleazy, but it worked ok.
Talk about sleazy, looks like Emerson really got the tube count up on that model.
