Old 07-10-2015, 03:09 PM
Adam's Avatar
Adam Adam is offline
1962 rca 19" b&w kcs140
I got this TV working with just the usual recap of wax/paper caps (there weren't many) and electrolytics. And then there was a iffy and dirty H hold control. The plastic in-between the H and V windings on the yoke is just breaking apart which worries me, but the yoke works as-is (The last pic shows the yoke). One corner of the plastic back is coming apart too, but I should be able to put that back together.
Old 07-10-2015, 05:39 PM
Findm-Keepm's Avatar
Followin' the Rules...
Sugru for the yoke? I've used it to mount a little circuit board to a yoke on an Admiral, and to "lock" a disentegrating purity ring assembly on a Zenith roundie.
Brian
USN RET 22YRS (Avionics/Cal)
Old 07-13-2015, 11:16 PM
Adam's Avatar
I never heard of that stuff before, I had to google it. It says it's non-conductive, so it would probably work. But I did a quick ebay search a few days ago and got lucky and found another yoke. I had also thought the H hold control was bad, that it had spots that were totally worn through, as sometimes I would barely touch it and the H freq would go way off, but strangely with the new yoke it doesn't do that. I also replaced a 1B3 with a cracked base. I still have to fix that cracked back before I put it back together though.
Old 07-13-2015, 11:43 PM
rca2000's Avatar
rca2000 rca2000 is offline
Cold..or HOT...chassis? I do NOT expect it uses a tube LV rect--likely silicon diodes..in a doubler or FW rect.
Old 07-13-2015, 11:58 PM
Adam's Avatar
Cold chassis, with silicon diodes in a voltage doubler. But RCA tried all the different variations in power supplies. I also have a 59 and 61 RCA b/w portables. The 59 uses a power transformer and a 5U4, and the 61 is a hot chassis.
Old 07-14-2015, 08:09 AM
DavGoodlin's Avatar
Motorola Minion
That is a neat set. Those years of RCA portables seem to be very rare.
-Dave G
Old 07-21-2015, 01:23 PM
Adam's Avatar
And I think the 59 - early 60s RCA portables are some of the best looking sets.
Most glues would not stick to the back. I was finally able to repair it, but not in a way in which the repairs were not visible. So I tried to paint it, and then the paint didn't stick either! Stripper would eat right through this plastic. Now would I have to scrape and sand all this bad paint off the back and try again. Sometimes if you put on a really light coat, let it dry for a day, and then put the paint on heavier, it won't lift like this.
Old 07-21-2015, 04:55 PM
Easy Off Oven Cleaner will probably take off the paint without hurting the plastic.
As always, try it on an inconspicuous place first.
