Old 06-14-2015, 07:59 PM
Cruiseomatic's Avatar
Cruiseomatic Cruiseomatic is offline
2 many toys,Not enough $$
Question Wood cleaning of nicotine
Got a mahogany cabinet coated in nicotine and want to thoroughly clean it. Searched online and didn't find much. The mahogany is stained and with a photo finish on the doors. Windex worked in an area but i didn't do to much with it. Also, I believe the cabinet also has Bakelite parts(cabinet 1953) Might be plastic, same thing, they need cleaned. Any suggestions?
Old 06-15-2015, 10:49 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
I use white Goop hand cleaner and a toothbrush. You'll see it just lift the stains away. Works amazingly well.
Old 06-15-2015, 12:20 PM
Both of my parents smoked non-filtered Camels. All through the years, there was never a nicotine buildup on the TV or furniture.
I guess, all that nastyness went in your lungs instead.
Old 06-15-2015, 12:30 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Makes me think of what Burgess Meredith said about that in one of the Grumpy Old Men movies: "I'm ninety-five years old, what do I care?"
Hopefully that doesn't ruffle any feathers, I just think that character is one of the best in those movies. He rules as the Penguin too.
Old 06-15-2015, 02:09 PM
My solution to unpleasant smoke smell in electronics: Turn it on and smoke my pipe tobacco nearby to give it a peasant smoke smell.
Old 06-15-2015, 04:15 PM
Jon A.'s Avatar
I've got to remember that one. Another benefit of smoking a pipe is that almost no one will bother you for cigs.
Old 06-16-2015, 10:56 AM
I don't smoke but where the set came from they did. One nasty money wasting habit.....I'll try the white goop method. I know that stuff eats dirt and grease off my hands when they're covered after working on a truck.
Old 06-22-2015, 08:08 AM
Radiotronman's Avatar
Radiotronman Radiotronman is offline
I had a couple of sets like that. I used easy off oven spray, applying to a rag then applying. I had a rca 721ts that was nearly black on the top, with a little buffing it took it all completely off with a high gloss finish. I was thinking of stripping it before I tried that.
Old 07-08-2015, 01:48 AM
fsjonsey's Avatar
fsjonsey fsjonsey is offline
Living The Draper Ethos
Zep Fast 505 is my magic bullet for tobacco tar.
I work part time at a cigar shop, and we smoke inside. A lot. Imagine the size of an average cigar compared to a cigarette. Imagine 5-20 people smoking said cigars in an inclosed 900sq. Ft. space (with excellent air filtration, of my own personal design. Getting my coworkers and my cheapskate boss to remember to turn it on is another story, ugh) for 5-12 hours a day, Seven days a week. This is my reality. I know tar. Fast 505 works. I use it to clean everything from UAS Smokeeter air purifier collection cells to painted walls, to furniture, light fixtures, and interior woodwork. It MELTS tobacco tar on contact. You can get it at Home Depot. It smells like Lemon and isn't noxious or toxic. All you need to do is spray it on the nicotine coated surface, wait 30 seconds to a minute, and wipe it off. To be safe, Try it on a small, inconspicuous area first to make sure it doesn't react with the finish. I haven't had any problem with finished wood surfaces, personally. Just don't leave it on too long and you'll be fine.
http://www.zepcommercial.com/product...-and-Degreaser
Oven cleaner is extremely corrosive, and contains lye. It attacks Aluminum and Steel with a vengeance. I could only imagine what it does to wood finishes. I had to throw out a set of aluminum smokeeter collection cells because my boss repeatedly cleaned them with Easy-off and corroded them to all hell.
Old 07-08-2015, 11:11 AM
Jon A.'s Avatar
Available in Canada too, I've got to try that.
Old 07-08-2015, 12:17 PM
A little off-topic, but Goop works well on plastic insulated wiring, too. De-gunks, reveals the insulation color, and doesn't dry it out. Discovered this on old car wiring, but works on old electronics as well. Stands to reason, since they use the same electrons.
Chip
Old 07-08-2015, 12:38 PM
I never took up smoking. People start smoking in high school, trying to look cool. I knew I was way to nerdy for smoking to do me any good in that area, so I never bothered.
Old 07-08-2015, 04:15 PM
Jon A.'s Avatar
Haha, sounds a lot like me. Same goes for drinking. That's one advantage of never having been part of the "in" crowd.
Old 07-09-2015, 10:38 AM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
Actually it's the TAR in the cigarette smoke that turns everything brown and stinky. Ammonia glass cleaner cuts it pretty well.
Speaking of starting smoking, put me down at about 2 to 3. My mother used to give me drags off her cigs when I was that young, and later I would "steal" cigs from her during the day, go out in the alley yard or garage and smoke away, with my buddy from across the alley. Mom knew and did nothing about it. My father despised it. Mom had to stop about 3 or 4 in the afternoon to get the house relatively cleared out by the time he would get home. I quit when I was 21, in 1972, after as lifetime growing up in a house full of stratified layers of cig smoke through the house. gag.
Old 07-09-2015, 10:59 AM
vts1134's Avatar
vts1134 vts1134 is offline
Looking For Time
Chip
Any one tried this on older rubber insulated wire?
John
