Old 06-21-2015, 12:34 AM
Nice progress. Those sets are very cool.
Old 06-23-2015, 07:58 AM
Radiotronman's Avatar
Radiotronman Radiotronman is offline
We have life!
Ok,
I changed the remaining three electrolytic canned capacitors and the power resistors and I was rewarded with a one inch line on the screen! So at least we know the flyback isn't gone. Now to figure out why I'm getting insufficient height. If I turn brightness up or down, the raster will disappear.....
Old 06-23-2015, 11:07 AM
IsthmusTV's Avatar
Nice work! Have you tried carefully adjusting the ion trap?
You've come a long way and you're getting really close!
-Clark
Old 06-23-2015, 03:41 PM
It didn't have an ion trap on the crt when I got it. I can try one from another set and see if there's any change. Thanks!
Old 06-23-2015, 03:52 PM
If it doesn't have one and you see something on the screen, it doesn't need one. Probably an aluminized CRT like a 10FP4.
Old 06-23-2015, 10:04 PM
Finally some progress
After swapping out a couple of tubes I was rewarded with a picture and audio! It only has 4000volts at the second anode, but definty progress. Now I have to figure out my insufficient high voltage priblem.
Old 06-27-2015, 02:34 PM
damen's Avatar
damen damen is offline
Your set is looking great and what a nice job you did on the cabinet replacing the veneer. Does it have a Rouland picture tube?
Old 06-27-2015, 05:24 PM
Thanks Damen.
My set actually has a GE 12kp4 tube in it. Still working on where my high voltage is being pulled down. I love the looks of your set, especially with that brass trim in the grill cloth area.
Scott
Old 06-27-2015, 05:30 PM
IsthmusTV's Avatar
Hmm. If it has a 12LP4 as stated in an earlier post, that would normally require a double field ion trap. Probably a rebuild with a straight gun in it.
Looks like your getting close!
-Clark
Old 06-27-2015, 07:40 PM
damen's Avatar
Thanks Damen.
Scott
Thanks!! Hope you get the one like it from your friend. Be cool to have both. I know a lot of things could cause voltage to be low good luck on that.
Old 06-27-2015, 08:16 PM
I'm hoping to make the missing slats and side molding for the cabinet tomorrow morning. These 49 zeniths are the hardest to find. The switch to light up the clear prisms are so cool to me.
Old 06-28-2015, 08:57 PM
Worked on the case a little more this weekend, since the weather was nice. I finished making the slats and the top side molding, with vent cutouts.
Old 06-28-2015, 08:59 PM
This is the top side molding.
Old 06-29-2015, 11:30 AM
damen's Avatar
Wow!! That looks great
Old 06-30-2015, 02:41 PM
So I still only have 4000v at the second anode and can't find any obvious signs of why. Voltages at the horizontal output, damper and picture tube all test pretty close to the values listed in the schemstic.
