The CTC 203 was ther VERY last "thomson made" RCA chassis. If it has the seperate tuner--which most have..it can be made to be VERY reliable--aside from the Fly and the horiz. driver connections and a cap here and there in the SMPS .
The tubes used in them do NOT really have a lifespan...they run and RUN and RUN !! I would say 50K hours is a LOW estimate of life for them !!
I only have seen a couple bad ones--likely "infant mortality"--since they were only a few years old when the tubes died.....and did NOT show sings of heav use either.
A "new" tube..(actulaly form an OLDER set---with a chassis beyone repair)....and one set looked like NEW...till the owner tossed it out becasuse he thought it was "telling him to get rid ot it....and his other furniture".
(Actually...there WAS one more Thomson chassis after the 203...the ATC_113...BUT it is really a 203 with MORE digital features and RGB component inputs IIRC--instead of a whole new chassis )
Reason: mistakes
