Old 06-10-2015, 02:27 PM
Originally Posted by DaveWM View Post
in this order
check the line voltage, make sure the B+ supply is good,try new HV (horz out/damper/hv rectifier) tubes.
replace the boost cap (white ceramic tube .1 1kv).
check the resistor value in the Horz out tube screen.
I found the .1 boost cap on a terminal strip on the side of the high voltage enclosure, where the earlier models had them on the PC board.
