I've had about a 70% success rate even with leads broken off flush
with the glass, if I can get them clean. I glue a #20 wire to the glass with silicone glue. Soldered to that is a #30 tinned wire that I stick up against the broken lead. Then I blob that up with nitrocellulose based conductive silver paint, two or three layer. If it succeeds I cover the area over with paper and silicone that down. I don't try to silicone over the silver paint. This may not work with high current filaments. A #30 wire can take plenty of current if its only 1/4 inch long. |
Phil Nelson successfully repaired a broke-off wire on a 10BP4, using silver-filled epoxy. It wasn't a heater wire, though. No telling if this repair would carry heater current.
http://videokarma.org/showthread.php...apehart&page=4 |
