Old 06-02-2015, 08:35 AM
Wow, the 8KP4 can handle 18,000 volts on the anode, was this a tube for a projection set?
The deflection angles seem all wrong, the voltages seem quite different also.
8DP4's aren't all that hard to come by, either from a junk set or sometimes they pop up on eBay.
If the set is working you could just plug the tube in and see what happens, I'm guessing it won't require the Ion trap since it's Aluminized.
If it was up to me, I'd try it. You might have to jumper pin 6 to 10 for a focus source.
