Old 05-18-2015, 01:40 PM
radio nut's Avatar
radio nut radio nut is offline
Born in the wrong decade
bad screen?
I am trying to help a co worker out with his mother's tv. It is a flat screen and as soon as he gives me the info as far as make\model i will pass it along if need be.
The set in question has a black line towards the bottom that goes completely across the screen and also a pink line up and down towards the left side.
He sent me a picture and it really does not show up well. I will try and upload it here but am thinking that the screen itself is bad Since the set does this all the time even without any video source where the screen should be blue.
Am i coorect?
Old 05-18-2015, 01:52 PM
rca2000's Avatar
rca2000 rca2000 is offline
Most likely a bad panel...BUT it IS possible that a T-con could cause this...if the set uses one.
If pushing on the front of the panel ...or bending it (GENTLY), causes the lines to disappear/change...then a panel is DEFINITELY the problem.
Old 05-18-2015, 01:54 PM
radio nut's Avatar
well, he sent me the picture via text and i can set it as home screen or look at it but i can't find a way on my phone to save it to photos inorder to load it here! will try another option later?
Old 05-18-2015, 01:55 PM
radio nut's Avatar
T con?
Old 05-18-2015, 02:29 PM
rca2000's Avatar
It is a module--usually small--but not ALWAYS..that is between the panel and the signal board. ( occasionally...there will be a "line doubler board or such between it and the signal board--but not often). usually at top but i have seen them at the bottom.
Its purpose is to take the signals from the signal board and convert them into a format the various lines and columns of the panel can use. It CAN cause lines and /or distortion in the pix. Stands for "Timing and Control " board.
Old 05-18-2015, 03:34 PM
Old 05-18-2015, 11:30 PM
radio nut's Avatar
It is a RCA 50 inch lcd
Old 05-19-2015, 10:28 AM
radio nut's Avatar
Rca model led50b45rq dated april 2013
Old 05-20-2015, 09:55 AM
radio nut's Avatar
Does anyone know if this set has a tcon module?
