Old 05-14-2015, 07:22 PM
Alfonsol Alfonsol is offline
I tried the record button and the capstan in record mode works ok, but in play mode it doesn't turn.
so, the motor is ok, is something else.
Old 05-14-2015, 08:20 PM
If i press very hard the play button it works, i think it s a problem with the switches activated by the play button.
i will try it connected to a tv to see if i got image
Old 05-14-2015, 08:34 PM
I just tried with a tv and i got very good image, perfect tracking.
So my problem is related with the play button, i will clean the switches.
Old 05-14-2015, 10:58 PM
I cleaned the switch, and i still have to keep the play key pressed, but not as hard ss before.
i tried several tapes, i get good sound and good image.
The issues i have now are the play key and the belt that drives the loading mechanism that sometimes slip
Old 05-19-2015, 07:59 PM
still waiting for the belts.
So far heads are good and i have no tracking issues
Old 06-24-2015, 06:06 PM
i just changed the belt and now the loading mechanis is working properlyThe nly issue now is i have to keep pressed the play button. There is a mechanical issue, it do not activate one of the 2 switches if i don't keep it pressed.
