Old 03-04-2015, 08:29 PM
Tubejunke's Avatar
Have you tested all the tubes in the color section? If not I recommend doing so. My set had no color, then I tested the tubes in the color section, and found most were testing bad to very weak. After replacing all the color tubes that did not test decently the color section came back STRONG.
I did test the tubes a long time ago on my Hickok 6000A. I think I will do it again on my new B & K Precision 747. Oddly, I get color when the set wants to and when I do it is beautiful. It always seems to happen when I use a DVD/VCR combo and run the line E up a bit. Coincidence perhaps.
Old_coot88 mentioned the color killer adjustment. I am guite familiar with that adjustment. Worked with it last night and got the snow and color fringing. I backed off till that went away, and then a little more as some fringing was still there. The idea which follows common procedure is to shoot for the perfect black and white picture which I can achieve pretty much. Once I get the color actually working regularly I will go through the whole purity and convergence procedures using my vintage RCA dot bar generator.
Old 03-04-2015, 10:15 PM
While chasing the intermittent-color problem, leave the color killer adjustment full 'on', all the way to the stop, while troubleshooting.
In fact, you could leave it full 'on' these days, since everything is broadcast in color. Whereas in the old days when some broadcasting was still in B&W, the color killer circuit served to turn off the chroma to prevent color artifacts in the BW image.
It works by sensing the presence or absence of the burst signal.
Today, that function is moot unless something is being transmitted in actual (burstless) BW.
