Yes - don't power it up until you've replaced the white axial ceramic caps - there are two (maybe more). These Elmenco white caps will spew aluminum foil all over if they fail. The largest is right behind the leftmost potentiomer pair (height and AGC). It is a .1/1000V cap, C268. The other is standing on end, and in my set, was a .047/400V, C409. Both are are in close proximity to each other.
Update - my notes also show I replaced a third one, C555, a .22uf/ 400V in the degaussing circuit, and in mine, also a white elmenco ceramic. It wasn't on the board - just trace the wires off the degaussing switch to the cap. I too have an early portacolor, A WM213HWD-3.
Brian USN RET 22YRS (Avionics/Cal) CET-Consumer Repair and Avionics ('88) "Capacitor Cosmetologist since '79" When fuses go to work, they quit! Last edited by Findm-Keepm; 02-16-2015 at 01:26 PM. |
