Old 01-22-2015, 10:36 PM
footlooseman footlooseman is offline
Originally Posted by Magnavox300 View Post
I think I have the same set, what's the chassis number?
My unit says V-28-03-11. What is yours?
Old 01-28-2015, 11:08 AM
Last night I removed the chassis and when to go clean it up a bit before replacing the caps. I checked the flyback and found it had melted a little bit. Do you think I should reinsulated with rtv silicone like in Philco Model F4626M "Miss America" Television restore or has anyone found something better?
http://antiqueradio.org/PhilcoF4626MTelevision.htm
Old 01-28-2015, 02:21 PM
If that happened recently make sure the HO Tube is not red-plating. It does not look terribly bad as far as peeling goes. I'd probably get the chassis working and check to see if the doughnut is arcing to anything. If it is arcing coat it, if not I'd leave it be.
Old 02-14-2015, 08:29 PM
john f john f is offline
I spent the afternoon recapping my magnavox. Just finished but realized I missed one paper cap when I was ordering new. Have to pick one up locally. Regardless, it looks pretty good. Haven't adjusted the yoke to fill the screen yet.
