Originally Posted by Olorin67
That tube is definitely bad... The question is, why.? A capacitor may have failed causing the tube to overheat. You need to find out why before you pop in a new tube. If one cap is old enough to fail... There are probably others about to go.
The tube might simply be weak. It amazes me how you guys always seem to jump to conclusions, when eight out of ten TV failures (in the vacuum tube era) were caused by nothing more than weak or dead tubes. When I used to restore old TVs I found in the trash in my home town, I found that a simple tube replacement more often than not got the set working again. As an example, I once had a 1963 Zenith K-2739 23" TV that was missing all but two tubes (HV rectifier and CRT) when I found it in 1969 near the end of the street I grew up on. I replaced all the missing tubes, and was rewarded with a TV that worked very well. Then I moved in 1972 and was forced to give it up (no room for a console where I moved; long story and OT). Didn't have to do anything under the chassis to get it working as close to normally as I could at the time. The set probably would have worked a few more years if I had kept it.
