Old 01-31-2015, 08:15 PM
33.3 Hz would have made DD synchronous phono motors viable from square 1...At least for LP based machines...
To expand upon what I said earlier...If it works at lower input voltage (as I suspect it should) then I think what you will need to do is find an voltage at which it registers full scale, note that voltage and the current it draws. Then design a voltage divider to reduce the input voltage from full scale mark value to the actual value needed to get full scale needle deflection. Divide the voltage you measured earlier by the current it draws to find it's running resistance. It's running resistance will be in parallel with the bottom resistor of the voltage divider unless you scale the top resistor properly (then you don't need a bottom resistor).
