I would not say there is a lot of work to be done, looks good to me.
The sound was a little distorted, and the pic was a hair short, but I would not start tearing into it.
If it has wax caps then they should be replaced, any across the line cap if used should prob be replaced if its still there (not blown up).
the can caps can be felt to see if they are getting warm, if not I would leave them be.
If its a mid 60's set, then it maybe just find. Tube sets are pretty tolerant about resistor values (in most circuits). So unless there is a problem, replace parts can be a waste of time and may even cause problems (wrong value or damage done in the replacement).
I mostly just clean up dirty pots and see how it performs after warming up a bit.
