Old 01-15-2015, 06:15 PM
The linear tracking arm that the cartridge is mounted on, does it move if you hold the fast forward button?
No.
The tracking assembly is gear driven (woo, no belts!) and functions properly. I can sit around and it will slowly track across the disc over an hour, then return back to the start and repeat because it does that. If what you are saying is the case then either the stylus can't get anything off any of the discs I try or that whole circuit is not functioning. I'm assuming that Fast Forward is directly tied to that time code it's not getting? Again, have no idea where to be looking.
