As for the color check to see it the 3.58Mhz reference oscillator is running. If so try adjusting the color killer and fine tuning* to see if you can get some color. Also many Zenith roundys had a switch on the color level control to turn off the color if that switch is bad it would explain no color reaching the screen. If all that is good and still no color then grab a scope and start following the color signal from the place the color splits off of the video to the CRT. *I usually tune the same program on another set and tweak it so that saturated colors show a slight checker board on the monochrome limited set. When one runs out of possible low hanging fruit trouble shooting, the next logical thing to do is usually signal tracing.
