That is a nice looking Zenith!
I believe I've offered before to look up the service info for you if you can give me the chassis number. If you don't know the chassis number, then remove the back cover and there should be a chassis number printed on a sticker on the HV cage right in plain sight, if that sticker is gone then look for one pasted to the inside of one of the sides of the cabinet. I tend to agree with you Jon as to the most likely chassis to be in it. I have a 12B13C52 chassis set, and from literature I've seen that chassis was offered with the same control layout as marco has. The chassis number is always the best identifier of a Zenith set IMHO since the service data is cataloged to make that the easiest number to look up, and the fact that Zenith usually offered the same chassis in various cabinets with a different model number on each cabinet.
