Old 01-02-2015, 08:41 AM
Marco-nix's Avatar
Marco-nix Marco-nix is offline
Wink
Originally Posted by Dreamsbeard View Post
What problems exacly? People may be able to help if you describe specific problems.
I have the same problems as your television. Finally, almost all ... according to what I see on the pictures you put in your message, mine has the same problems.
Old 01-02-2015, 10:09 AM
Dreamsbeard's Avatar
Dreamsbeard Dreamsbeard is offline
Right! In that case stay tuned.
So I found the pin adjustment pot (you can get to it on the right side of the set as showed in the picture), and got rid of the hourglass shaped picture.
Also found the F1, F2 and F3 focus holes (see picture 2) , If I understand correcly the wire starts from F0 and goes to either F1, 2 or 3 right? So in order to try and adjust the focus I have to unsolder the wire from F1 and try F2 or F3?
As for the colour kicking in and out , I think its the CRT board because while adjusting the Pin cushion, I was gently tapping the board with my plastic tool and found that it accentuated the problem...so I will reflow the suspects connection.
