Old 12-29-2014, 08:31 AM
rose14 rose14 is offline
Do small tvs last longer?
It seems like sets that are 20'' or smaller live longer lives. I would like too know if this is true or not. Thanks for any info.
Old 12-29-2014, 08:37 AM
jstout66 jstout66 is offline
Well.. I noticed that as well, but I think it's because the smaller sets were rarely used as "main" TV's. They were always bedroom sets or a secondary set, so didn't see the use that the larger screen sets did.
Old 12-29-2014, 10:15 AM
Even the 20" Zenith CRT's stood up well, compared to their ratty 27's.
A lot of those sets were the only sets, the owners had. I see a few 13's that look a little tired.
Old 12-29-2014, 11:34 AM
Celt's Avatar
Celt Celt is offline
Peanut Head
In my experience the smaller sets lasted longer than the larger ones.
Old 12-29-2014, 02:15 PM
Chock some of that up to strain. Sometimes a maker will use the same (or nearly the same) chassis/main board to drive more than one screen size, and odds are when that happens the ones that have the worse stress on the high power parts are the biggest screen incarnations of the chassis.
Old 12-30-2014, 12:55 PM
Celt's Avatar
Peanut Head
Yes...I once had a 25" RCA console that had pin settings for which CRT was to be used. 13" and on up.
Old 12-30-2014, 01:08 PM
Old 12-31-2014, 01:02 PM
RCA used the CTC203 chassis in everything from 19" all the way up to 36". It's been my experience that the 19" to 27" sets held up fairly well; but, anything bigger than 27" would eat flyback transformers. I'm sure the reason for that is because they didn't use a heavy enough flyback to drive the larger CRT's.
Old 01-01-2015, 02:31 AM
rcaman's Avatar
rcaman rcaman is offline
the rca ctc110 13" sets seems to run forever. i sold quite a few of those and i never seen a bad or weak crt in those. my mom ran hers all night every night for years and years. then it went to her flower shop where it ran day in and day out for years and was still making an excellent picture when it fell off the shelf.
steve
Old 01-01-2015, 02:33 AM
rcaman's Avatar
the crt's in rca 25" sets chassis ct-107 thru ctc120 ran a long time i mean years before showing signs of getting the least bit weak. thomson made some of the best crt's out there.
Old 06-12-2015, 12:44 PM
MRX37 MRX37 is offline
IIRC the CTC 120 was out around 1984. Thomson didn't purchase RCA until 1986
But the ColorTrak 2000 TV's from the early 90's were damn good sets. Used to have one.
Old 06-12-2015, 01:33 PM
rca2000's Avatar
rca2000 rca2000 is offline
The CTC 203 was ther VERY last "thomson made" RCA chassis. If it has the seperate tuner--which most have..it can be made to be VERY reliable--aside from the Fly and the horiz. driver connections and a cap here and there in the SMPS .
The tubes used in them do NOT really have a lifespan...they run and RUN and RUN !! I would say 50K hours is a LOW estimate of life for them !!
I only have seen a couple bad ones--likely "infant mortality"--since they were only a few years old when the tubes died.....and did NOT show sings of heav use either.
A "new" tube..(actulaly form an OLDER set---with a chassis beyone repair)....and one set looked like NEW...till the owner tossed it out becasuse he thought it was "telling him to get rid ot it....and his other furniture".
(Actually...there WAS one more Thomson chassis after the 203...the ATC_113...BUT it is really a 203 with MORE digital features and RGB component inputs IIRC--instead of a whole new chassis )
Old 06-12-2015, 01:59 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
steve
I have a 19" CRT from a CTC110B that tests almost new even though it probably has a considerable number of hours on it (quite a bit of black dust came off).
Old 06-12-2015, 02:47 PM
I have a CTC-185 25" that I bout new in 2000. It had a TON of hours on it until it got "retired in 2014. I gave it to a friend in 2005, and she used it until being put in storage last year. Last time I saw it, it had a great picture, and surprisingly has never needed a repair...
Old 06-12-2015, 07:14 PM
My RCA CTC185, bought new in 1999, still works and has an excellent picture for its age (almost 16 years). I also have a Zenith 19" "Sentry 2" table model (model SMS1917SG) that still works quite well, even after almost 20 years (it was a birthday present on my 39th birthday in 1995). That Zenith is still practically new, however, since I only used it four years before moving and replacing it with the above-mentioned RCA; the Zenith has been in my bedroom, unused, since then.
My Zenith Sentry 2 was probably one of the last if not the last Zenith sets to have been manufactured while Zenith was still an American TV maker, based in Chicago. There is a label on the back cover that says "Zenith Radio Corporation, Glenview, Illinois 60025", so that set probably was one of the last "real" and quality-made Zenith TVs manufactured before the company went to Korea, and their reputation for quality went with it. However, I guess I shouldn't be too hard on Zenith of Korea, as they did have some good products. I have a Zenith portable AM-FM radio, model R-70, which was made in Korea to Zenith's standards (there is a label stamped into the back cover of the radio stating this), and it's a fairly good set for its age (almost 35 years). Four IF stages on FM, two IFs on AM, and ceramic filters for both bands, with a 4-inch speaker, made this one of the best, IMHO, small portable radios Zenith ever made in the early 1980s. I will hold on to mine as long as it works, even though I don't listen to radio now as much as I once did.
I also had a Zenith integrated stereo system in the early '80s, made by Zenith of Korea; it worked well the 17 years I owned it, but I left it at my former residence when I moved. Replaced it with an Aiwa bookshelf stereo that still works, for the most part, but the cassette decks failed several years ago. I'm not surprised. Those decks had cheap plastic parts in them, and a few of them must have cracked or broken, putting the decks out of service. I replaced both decks with a now 38-year-old Radio Shack stereo deck with Dolby (not sure if it's A or B) that still works like a champ today, even though I do not use the Dolby decoder since only one of my many cassettes was recorded with Dolby noise reduction.
Back to the question which is the topic of this thread: I do believe smaller TVs can last much longer than sets with larger screens, due to the lower beam current requirements of flat screen TVs and small CRT sets, not to mention lower power requirements of the entire set. This can also be said, I believe, for flat screen TVs: the smaller screens seem to outlast large-screen sets, as I consistently see in the support forum for Insignia flat TVs (I browse it regularly). Most of the service inquiries involve the larger sets (30 inches and up), as I rarely see smaller screen sizes mentioned in these forums. My own Insignia 19" flat panel TV has almost four years on it, and hasn't given me five minutes worth of trouble; still works as well as when it was new. Knock on wood.
