Old 12-25-2014, 05:15 PM
vs. "All hand wired - no production shortcuts" for Zenith.
I knew someone who was an engineer at Zenith, and he told me about the use of those strange terminal strips Zenith used. The ones with rows of cones. Production workers would stuff resistor and cap leads into the appropriate cones, and the chassis would then be sent thru a wave solder machine to solder all the terminals. Then a saw of some sort would trim excessive lead length. Parts that would protrude above the chassis (and thus end up in the solder bath) would be added later, things like IF cans and vertical output transformers.
He told me of a problem Zenith had with some early ICs in TV sets. Seems these ICs were designed to fit tube sockets. The assembly line workers used a rubber hammer to press this chip into the socket. Intermittent problems would sometimes happen in the field, and once they told the workers to not use that hammer the problems went away.
