Old 12-19-2014, 04:09 AM
fsjonsey's Avatar
fsjonsey fsjonsey is offline
Living The Draper Ethos
Well, I replaced all the caps and the bottom of the horiz has started to collapse again. I can't get the HV over 22KV. The Flyback still looks good and resistance is in spec. I looked at the VDR, and it's already been replaced at least once, some other tech tacked a pink and white Zenith replacement VDR onto the leads of the original. I ordered one of the replacement Speer MOV's that Doug recommended in another thread. It should be here today. I'll let you all know the results once I solder it in. It would be hilarious if the caps were either fine or marginal and the VDR was the real culprit. If that's the case, I guess that'll teach me not to trust a $30 Chinese ESR cap tester.
