Old 11-14-2014, 10:56 PM
Olorin67 Olorin67 is offline
They have gotten hard to find, and of course not suitable for stereo records anyway. There was a red version , and a green, one for 78s and the other for Lp/45, and a lot of these were equipped with a compromise needle that wasn't the right size for either type of record. Hard to replace with a regular cartridge, without some modification. These use an oscillator to feed a coil in the cartridge. The moving vane attached to the needle varies the inductance of the coil, modulating the oscillator signal, which then feeds into a detector that demodulates the AM modulated signal. To fit a regular cartridge requires wiring into the first audio stage. (or a pre-amp too for a magnetic cart)
Searching for Zenith Cobra cartridge turned up new ones for $70. Not sure how the quality is, these are reproductions. The needles are not replaceable, you have to pop in a whole cartridge.
