Old 11-14-2014, 07:33 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Late-model filter can contents
This was tied to a CTC110B chassis from 1982. I thought it unusual to see an old-style filter can on such a recent chassis. It was a single-section can though.
I want to rebuild the cans in my Admiral so I thought I would get some practice by taking this one apart. I used heat to remove the guts as described in the sticky above. The tar holding everything in was almost entirely at the top. I was surprised to find cutouts for three other terminals in the rubber and plastic spacers. I didn't have to snip the plate lead as it was detachable.
I'm going to see if I can find a way to rebuild these so that they can be maintained easily but look as close to original as possible. Hopefully I won't completely destroy this one while experimenting, but if I do, no big loss.
I decided to take a picture due to the differences between this can and the one in the tutorial. Interesting if nothing else. I didn't melt the rubber spacer, I damaged it with the pliers. Also, I eventually learned how to pry up the bottom edge of the can without damage. I found prying and lifting at the same time turned the trick.
