Old 10-26-2014, 07:51 PM
rca2000's Avatar
rca2000 rca2000 is offline
I do not think so...the final "dense hybrid' color sets--with under 10 tubes--often did not use any regulator tube at all. Our beloved 4 tube Zeniths are a good example. Nothing much more than a VDR or 2 to control the voltage applied to a feedback ckt from the flyback--tied in the grid ckt. of the H-out tube. I suspect this is quite similar. By 71--NO set used a shunt reg. I think--and not nearly all used a pulse reg (such as the 6KV6 or 6HS5). By that time--mfg's were finding it easier to eliminate them--just using a vdr or 2 as the reg.element.
STILL my favorite--is the old reliable 6BK4 shunt reg. tube--as used in my 1969 or so Sylvania D-12 set--I think it has 9 or 10 tubes or so. FULL SS audio and IF. One is a shunt reg, one is an HV rect. Later sets that used triplers eliminated both of those tubes--such as the D-16 set.
