Old 09-06-2014, 09:47 PM
Gregb Gregb is offline
Nice set! Wish something like that would show up around here.
Gregb
Old 09-06-2014, 09:58 PM
decojoe67's Avatar
Nice example! If you need to put numbers on the channel ring, you can get rub-on one's from art-supply stores. It takes patience, but comes-out very nice. You first polish the ring, apply the numbers, and spray coat with clear. I did it on my RCA 621 and it looks totally original.
Old 09-07-2014, 12:02 PM
azbigsam azbigsam is offline
Thanks for the tip. I hadn't decided if I wanted to mess with it or leave it as is. Do you have a close up of the one you did?
Old 09-07-2014, 05:15 PM
stromberg67's Avatar
stromberg67 stromberg67 is offline
Congratulations on the addition to your handsome display! Hope the problem turns out to be a simple fix.
Kevin
Old 09-07-2014, 05:29 PM
decojoe67's Avatar
I snapped a quick pic for you. I was thinking about it and I must have did the job 20+ years ago! With the wear it really looks original!
Old 09-07-2014, 10:46 PM
hi_volt's Avatar
hi_volt hi_volt is offline
Vintage TV and Radio Nut
Nice score Sam!
