Old 08-21-2014, 08:49 PM
tvcollector's Avatar
Originally Posted by Robb View Post
That is because this set was used as a Professional monitor.
I paid $120 plus shipping.. Seeing how it's a set I've been wanting.. The condition that it's in, I'd say the price is fair.. More than what you are willing to pay for a Portacolor?
Old 08-21-2014, 08:58 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Whatever the mods are, if any, consider it part of the set's history. The original owners of my 1988 Zenith console screwed a small knife switch to the back panel for antenna selection. That left a couple of non-original holes, but whatever. Not only am I leaving the switch there, I tightened a loose terminal on it.
Old 08-22-2014, 01:19 AM
Someone was wanting pictures of the back connectors:
Old 08-22-2014, 10:25 AM
kx250rider's Avatar
REAL TVs have TUBES!
Another possibility is that the back cover was replaced with a new one due to the "white powder deterioration" problem of those black plastic covers. The factory replacements had no tags, but the embossed Japanese model number was there. I say you have a replaced back.
Charles
Old 08-22-2014, 10:31 AM
This still could be CVM-1225. When I blow up the VHF channel selector, I don't see channel 1 which you would see on a Japananese set. Can you verify?
Speculation here: the missing red metal tag may have had the correct U.S. Voltage and model CVM-1225 and for efficiency in manufacturing that may be why Sony put the red tag in the first place for U.S. models so they did not have to manufacture separate plastic back covers.
Domestic market called it a 12 inch, measuring viewing size, not total size of envelope.
I have a KV 1210U and KV 1220U. Would be interesting to see what is behind the red tags?
Old 08-22-2014, 11:58 AM
mpatoray's Avatar
mpatoray mpatoray is offline
I have the monitor version of this set great picture, I use it with my TI-99/4A computer. The UHF tuner has letters because it uses a preset style of UHF tuner, see that little screw mechanism above the UHF tuner that displays what channel it is on.
Matt
Old 08-22-2014, 12:02 PM
As long as you were photographing the back, you should've placed the power cord, so we could see the plug.
If it has an original two prong, molded plug, with a grounding pig-tail, it definately was built for the Japanese market.
Old 08-22-2014, 12:09 PM
Man! That's cold blooded!
Old 08-22-2014, 12:47 PM
zenith2134's Avatar
You sure did pay a premium for it, but it's certainly a nice one, and unique too.
Let's see a screenshot sometime.
Old 08-22-2014, 02:27 PM
jstout66 jstout66 is offline
Dieseljeep! Cold blooded, but it still made me laugh.. lol!
The "want to buy a Portacolor" thread is about as old and long as Firebirds post on his Magnavox issues.
Old 08-22-2014, 03:19 PM
Jon A.'s Avatar
One thing about collecting older electronics is that you've got to either know how to fix them or be able and willing to learn. Anyone else is just a user and should stay away from them. Notice the labels on SS equipment that say "No user serviceable parts inside". Anything older, well, it's almost guaranteed to have bad parts that aren't "user serviceable".
Old 08-22-2014, 05:43 PM
On the contrary, they were full of user serviceable parts (tubes), and tube testers were available at many locations. Many times I have seen non-tech people with a bag or two of tubes, checking them out at a "drugstore tester" and wondering if they indeed ended up buying proper replacements and got all the tubes back in the proper sockets.
There were also several paperbacks published with pictures of more common faults that could occur, indicating tube types that could possibly cause that problem.
DIY TV repair by totally non-tech people was common before SS sets became available.
Old 08-22-2014, 05:55 PM
Jon A.'s Avatar
Never mind, others can take the time to read my previous post carefully.
Last edited by Jon A.; 08-22-2014 at 05:57 PM. Reason: Sigh, tube assumption again.
Old 08-22-2014, 06:10 PM
I don't know a lick on how to fix televisions, but I can appreciate and collect them. I just make sure the ones I collect are in good operating order.
I remember those drugstore tube testers. I was soured away from tube television because of the constant failures of the family black and white in the mid 50's to early. 60 's. My parents had to hire a repairman to come on a frequent basis. When it was time, I finally bought my first color set, a year after graduating high school in 1965. Even then, I wanted to buy the Motorola "works in a drawer" all transistor console, but it was too expensive, so settled on the RCA 19 inch consolette CTC 19. When the first all transistor Sony color sets came out, quickly ditched the RCA.
As I was not handy with television repair, I wanted to stay as far away from tube sets as possible. My perception at the time was transistor sets were more reliable, transistors don't burn out like tubes. I hope I didn't stray to far off topic.
Old 08-22-2014, 07:11 PM
Transistors do not "burn out" as do vacuum tubes, since, of course, transistors do not have filaments; however, they can short or develop intermittent connections. The other hazard to watch out for with transistor TVs, radios, etc. is, if you use them with outdoor antennas (or even indoor ones), static charges. These can destroy transistors in an instant; there are no second chances.
Static electricity from wool or nylon carpets, etc. injected into the set through the antenna can ruin solid-state gear just that quickly. I read years ago of someone who inadvertently did a tremendous amount of damage to his solid-state clock radio, stereo system, lamp dimmers, etc. because of static electricity. It is almost incredible how much current a single static spark can carry. Touch a solid-state radio or TV's indoor antenna without discharging yourself to a grounded surface first and, nine times out of ten, the tremendous static charge will damage or destroy the antenna coil and/or tuner in the blink of an eye.
