I have done the simple green and water soak to a few nicotine gunked chassis and the best tip I could give would be to take steps to keep the water out of the IF cans by putting a small piece of duct tape over the top and bottom holes
I always like to blow out what loose dirt/dust there is first before anything else using low pressure air of course and assorted brushes if need be. As for anything beyond that I treat on a case by case basis, and good suggestions are mentioned here. Although I agree with DaveWM just clean enough so you can troubleshoot.
As an aside, I've worked on quite a few vintage Fender guitar amps and there was no way to even touch 'em without getting your fingers all sticky from the nicotine residue besides the reeking smell. For nasty covered metal chassis's a good bug and tar remover will work wonders. As with any solvent use outdoors and nitrile gloves are handy too. |
We used to have to take measures to keep liquid out of the focus and screen pots on the flybacks, too... sealed the pots with liquid electrical tape... but not an issue on an older chassis.
