Old 07-05-2014, 10:34 AM
RetroHacker RetroHacker is offline
Electronics Accumulator
Recent CL find - Admiral color console
I happened to check CL recently, and came across a posting giving away two old TV's - this Admiral, and a solid state Sylvania console. I called, and met up with him, and had a great time talking to him - definitely a fellow hobbyist, with a long history of TV repair and electronic tinkerings. He even had the Photofact for the Admiral, from having repaired it previously. This set had been his daily watcher for years, until it was replaced with the Sylvania in the 80's, then, that got replaced by a flatscreen within the last couple of years. He had, years back, put a new flyback in it, so it has the Thordarson replacement fitted. It was working when stored in the 80's, but, he said the last time he powered it up, a year or so back, he got a zapping noise and shut it off again.
This is an Admiral G13 chassis set from 1967. Photofact 915-1. This one has the 25" tube.
The cabinet is pretty good, with a fair bit of wear, but not bad. The legs are coming unglued, and one dropped off while I was carrying it into the house, so I've temporarily got that corner of the set supported by an old external SCSI disk and a stack of paper. I need to flip the set upside down and reglue/clamp them. The chassis is dirty, but not overly so - about average for a television that's several decades old.
First tests, I took the chassis out and inspected for any obvious burn marks, and metered the power supply filter caps to see if there was anything horribly shorted. A large electrolytic had been soldered in previously in parallel with one of the main filter sections, but neither tested shorted. Overall, looked OK, so I brought it up slowly. Tube filaments lit up, dial lights, and then some humming static from the speaker. No high voltage, but, after a minute, there was a pop and a flash from under the chassis and the humming got a lot louder, so I shut it off.
I pulled the chassis and checked it out, and saw that the replacement electrolytic had vented out the side. Checking again, one of the cap sections was partially shorted. Time to get replacing. I fortunately had a fair stock of parts on hand, enough to replace the main filter cans with new components of fairly close values, always erring on the side of larger value caps. I first replaced the tall can containing the primary filters and the one that had been bypassed. I cut the can off at the base, and mounted one of the new caps by drilling holes through the old base and mounting it on top - the other two were snap-type electrolytics that I was able to zip-tie to the chassis underneath and wire up. With the larger can replaced, I tried it again, this time I was rewarded with high voltage and a sickly purple picture with insufficient height and a hum in the speaker.
Progress!
I proceeded to cut off the other can, and replace it with new components as well. I re-purposed one of the lugs as a negative terminal and mounted the smallest cap under the chassis, allowing me to attach the other three above and wire them neatly.
Cutting the cans open like this, you can really see just how crummy these old electrolytics get after all these years. The tallest can had very obviously leaked internally and the electrolyte paste was staining the base disc in places. The other, smaller can, the paste had badly dried up, and the whole thing had shrunken internally, so when I cut it off, it fell out of the can.
After that replacement, I got a much more stable screen full of purple static, and no hum. I reassembled it and checked it out with an input source, and was able to dial in the color and the picture somewhat OK. It still has a long way to go, but it's alive and running.
The tube is weak, and has a bad case of cataracts. There is a a fair bit of horizontal smearing and fringing. The audio is pretty good though, and all the controls are smooth. The convergence is pretty good as well. Overall, it's in good shape - and it'll take some more work to make it perfect, but, getting this good of a picture out of it this early is very encouraging.
-Ian
