Old 06-25-2014, 07:22 AM
IHMO the best way to discharge a CRT is with a HV probe. You need one often enough in workign on sets to warrant buying one. Once you have it you can use it to verify the CRT charge status. they are designed to be insulated properly against high voltage. Touch the bell with the HV prob (with the ground attached) and check the voltage or any residual charge. Leave it attached for a min or two as the charge can recover.
With a metal bell crt the CRT does not have the same built in capacitance (internal dag glass bell external dag). But the bell may be attached to an anode lead with a door knob cap in the HV cage OR the the metal bell may have a plastic shell that has a conductive coating on the outside again forming a cap.
Old 06-25-2014, 09:18 AM
According to the Sams, it has a 500PF door knob cap.
I hated those CRT's with a passion! Most were easy to install, but hard to substitute.
BTW, they were invented, by an engineer at a Milwaukee metal spinning concern. The round ones are easy to see, how they were formed, but the rectangular ones???
Must have been several operations.
Old 06-25-2014, 01:40 PM
VintagePC's Avatar
Tube bug got me 05/2010
Were there rectangular metal CRTs? yikes, that must have been pretty thick metal to withstand the vacuum pressure since it doesn't have the same natural strength...
Old 06-26-2014, 04:09 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
I wouldn't want to do it any other way. A loud SNAP from using a grounded screwdriver would give me quite a start.
Old 06-26-2014, 08:25 PM
Those CRT's didn't seem to hold a charge as long as the glass CRT's. I always used to use a screw driver, propped between the yoke support brackets and the metal cone. Some had a vinyl plastic shield covering the metal cone, so you didn't have to worry about a shock.
