Old 05-16-2014, 12:41 PM
maxhifi's Avatar
maxhifi maxhifi is offline
Originally Posted by VintagePC View Post
My take... I used to do that too until I bought an 808 last fall. After I bought it I wish I had one earlier.
It may be a dedicated tool and while a sucker and an iron _can_ do the job... it makes things much easier, faster, and cleaner.
Solder suckers can be a bit finicky and if you are working odd angles or in tight spaces... sometimes it's hard to get the joint to stay hot enough so you can get the sucker in and remove the solder. Similarly, it can take several tries (and applications of fresh solder) to completely clean the joint.
The main upside here is that you can continue to heat the solder whilst applying suction - and the result is faster desoldering, probably 1-2 seconds per joint vs the 5-6 spent otherwise (assuming it's clean on the first go). Ergo, no need to heat well past the melting point and pray it stays liquid long enough without damaging what you are trying to remove.
The other thing you won't miss is the grit and pile of little flecks of solder you tend to get with a sucker no matter how careful you are to depress over a container of sorts. Nor will this gum up on you and have to be disassembled (spreading more crud) because there's a large glob or crushed strand preventing the plunger from locking down. (If it does block up, just pop in the cleaning tool and you're good to go in a few seconds)
Third: one-handed operation - unless you have a smaller sucker (in which case you may find it has low volume/sucking power) often they're big and awkward to manipulate while holding an iron in your other hand.
My bottom line is I'd recommend it if you do a lot of desoldering work and can afford it. You definitely won't regret. (and be sure to check out the vendor classifieds on AudioKarma as there are occasionally promotions there - it's what tipped the scale for me).
Man you make one compelling argument, every single point makes sense.. may have to put one of these on the list
