Loose crt sockets
The one constant I have been seeing is all the roundie crt sockets seem to be coming loose due to the age of the glue used to secure them when they were manufactured. Anybody aware of what type of adhesive they used when manufactured? My guess is it was some type of epoxy.
[IMG] |
Sorry, I thought you were addressing the socket, not the CRT base.
What ever was used is now long gone, for sure. My best results have been using the regular JB Weld. Apply glue to clean surfaces, place the item in the oven, set at 170 degrees. When set-point is reached, turn off oven and allow to cool while in oven. Works every time. Last edited by reeferman; 04-29-2014 at 10:50 PM. |
There was a special cement used to glue the base onto the tube, I don't know if it's made anymore. RACS in France used electronics safe adhesive, similar to silicone just without the corrosives in it. They drilled a small hole, and injected it through the base pin- that's what I would do.
Evolution... |
Thanks, Kevin
stromberg6 |
jr |
And how the heck did I wind up with two names on two different computers?! I'll check that out, too! |
jr |
I wouldn't use any kind of silicone sealants. If for no other reason the stuff is not rigid when it cures. They make a world of two part (I guess) epoxy type products like someone mentioned J-B Weld. But I wouldn't have thought of that. I would go for the plastic two part stuff or maybe better yet super glue.
The sockets get loose often from being not so gingerly separated when the set has been worked on. You have to hold the plug on the end of a c.r.t. tightly and gently wiggle the socket off. A shot of WD-40 or any other penetrating oil on the pins helps. If it's still stubborn, you can gently wedge with a medium screw driver working your way around the circumference.
"Face piles of trials with smiles, for it riles them to believe that you perceive the web they weave, and keep on thinking free" |
I use Permatex 81730 Flowable Silicone Windshield and Glass Sealer which does not contain acetic acid and is designed to bond well to glass. It holds the base on tightly but has just a little give to it.
It's my understanding that using a very hard adhesive like epoxy could cause the glass to crack if it has a different coefficient of expansion. Those necks can get pretty hot during operation. |
Way down at the bottom of this antique wireless article they give an old RCA formula for "tube basing cement".
http://www.antiquewireless.org/uploa...acuum_tube.pdf |
I've had great success for years with clear fingernail polish. Holds up to the heat well.
It had been referred to me by a through a radio/ham guy to use some Elmers white glue. Although you need to allow time to let it set up, I've been suprized by the results. No kidding!
