Old 04-12-2014, 08:31 PM
ok tuner clean is in order for now ill check back with you guys on an update. i am disapointed that i dont have the number listing for the crt to test but the numbers i have for the 13 inch crt are close so if the plug is the same then i may try it at 6.3 volts just to see how good the crt is.
Almost all modern CRT's use 6.3 filament. Use the most common set-up for similarly numbered CRT's. The pin-out for your CRT is:
Filament 10 & ?? ( blurred ) probably 9
red K 8
Blue K 11
Green K 6
G-1 5
G-2 7
Focus 1 ( always separate on socket )
