Maybe Zeno or another tech can guide you. |
Press & hold MENU Press POWER Press VOL UP you are now in service mode with Ch up change the left ## to 76 the channel up / down control the left number the vol up / down the right number. left # is the parameter, right number is the actual adjustment. After the first group of adjustments you will need to enter 77 to go further. then after that group enter 78. There are 3 groups & abt. 100 numbers write them all down. Be shure to get them right. If the eprom is the cause the audio will come back but the hoz sync is always off. Its the first adjustment & usually around 18 IIRC. BTW we had a few of these sets eating e-proms. Cured them by running a wire from the tuner shield to the ground at the e-prom. 73 Zeno
I have all the settings written down. What's next? Do i have to go through each of these or is there a certain peramiter for the audio?
Order it by complete chassis ##. Remember this may not be the cause but its the only audio problem ive seen on them & I worked on piles of them. 73 Zeno
You probably have a CTC 177AW2 chassis which takes a 234397 eeprom. I have some eeproms left over from my repair days but not that number.
Here is a site where you can get them for less than $3 each. They typically run less than $5. http://www.electronicsic.com/ep.htm
" I'm gonna fix that one of these days" |
