Old 03-18-2014, 08:49 PM
M3-SRT8's Avatar
M3-SRT8 M3-SRT8 is offline
It appears completely original.
The Tuner tubes are dated 3-43. The earliest 1946 tubes are dated 6-17. The 5U4 is missing.
The cad plated chassis is well preserved under all that dust.
All caps and resistors appear ex-factory.
Old 03-18-2014, 08:53 PM
M3-SRT8's Avatar
Using a soft brush, I swept aside a small section of dust from the top of the chassis. You can see thr cad plating is very nice.
Old 03-18-2014, 08:59 PM
M3-SRT8's Avatar
The 7DP4 appears origional to the set.
The black socket is marked MADE IN USA 043.
This is fun...
Old 03-19-2014, 11:27 AM
vts1134's Avatar
vts1134 vts1134 is offline
Looking For Time
Ever give a second thought about keeping it in its completely original condition? Relatively speaking "restored" "working" 621ts' are a dime a dozen, but examples as original as the one you currently have are probably quite rare, and getting rarer every day.
John
Old 03-19-2014, 01:08 PM
ChuckA's Avatar
ChuckA ChuckA is offline
RCA changed to a year-week code in 1946 so 6-17 is 17th week of 1946, if there is a dash it's an OEM tube, no dash it's a replacement tube.
Before that the code was a letter (Year) number (Month pair) combination, U=1937, F=1946; 1=Jan/Feb, 6=Nov/Dec, so 3-43 isn't an RCA date code.
In 1956 they changed again to the RMA-EIA code format YY-WW.
Chuck
www.myvintagetv.com
Learn from the mistakes of others -
You can't live long enough to make them all yourself.
Old 03-19-2014, 04:37 PM
M3-SRT8's Avatar
The latest tubes are 6SN7s, all dated 6-30, with a dash. All the tubes have dashes.
I haven't ventured inside the HV cage yet.
Soooo...6-30 is Mid-August. The sound discriminator is a 6AT6. An early production 621TS. Say, September 1946?
Old 03-21-2014, 09:08 PM
M3-SRT8's Avatar
Taking inventory and testing components. Cleaning and checking as I go.
All the ww resistors in the HV Cage and the bleeder resistors are fine. I checked the flyback for resistance and it is fine.
All the tubes test very good to excellent. Since all but four tubes are as the tv left the factory, I find that remarkable.
The only tubes, in fact, the only components that are not ex-factory are the 6BG6-G, 5V4-G, 5U4-G, and one of the 6SN7s.
Old 03-22-2014, 11:15 PM
M3-SRT8's Avatar
Checked all the transformers for resistance, and they're all fine.
Did a partial recap. Restuffed and replaced 17 out of 27 tubulars. They are the new looking caps at the right of the picture. I replaced them exactly as before, duplicating the factory positions.
On a lark, I plugged it into the variac and brought the a.c. up slowly. At 100 volts I tested the second anode and it read 7kV.
That's good enough for tonight.
Old 03-23-2014, 09:53 AM
kvflyer kvflyer is offline
Looks good as usual! What do you use to seal the ends of the capacitors after you "stuff" them. I have not been happy with what I have found so far. A good sealing wax may be the ticket but I have only found a kinda hot glue and I am not satisfied with the color.
Thanks for sharing and good luck today!
Old 03-23-2014, 04:12 PM
M3-SRT8's Avatar
So far, this is boiling down to a glorified recap. Strip away all the fancy re stuffing of cardboard capacitors, quick resistance checks, and this is a pretty simple restoration.
I'm using clear hot glue and dark amber colored beeswax on the caps.
Only a few more tubulars to go, under the video IF sections.
It appears the ion trap magnet assembly was replaced, with a stock RCA unit. Lead number 2 was disconnected. I don't know why it was left hanging...
I briefly power up the unit every three or four cabs replaced. Last test at 110 volts yielded a full 8 kilovolts at the second anode connection. Looks pretty healthy.
The original electrolytics are still on the chassis. I'm saving them for last. I'm only powering up the chassis briefly, so as to not endanger anything.
