Old 02-05-2014, 02:31 PM
Winky Dink's Avatar
Winky Dink Winky Dink is offline
- I did try another 6A7.
- Shadow meter shows 2.5Kohms, which I believe is proper.
- I did hook up the signal meter and found max output at the IF frequency with no adjustment to transformers.
I will post the IF transformer voltages as soon as I can be sure I'm not posting spurious data--like mixing up primary and secondary.
Thanks
Winky
Winky Dink
Damn the patina,
Full speed ahead!
Old 02-05-2014, 06:07 PM
Winky Dink's Avatar
The final score is 245 Volts on both ends of 1st IF transformer primary (and -2.5 Volts on the secondary).
Winky Dink
Damn the patina,
Full speed ahead!
Old 02-06-2014, 05:57 AM
Winky Dink's Avatar
I must be a genius radio-fixer guy.
Reece, thanks for your attention to my issue. Tonight I started following circuits from the problem grids, pulling out components to test them out of the circuit, and looking closely at every solder joint.
Found a cap that may not have been grounded due to a rusty bolt. That fixed the voltage at the anode grid. Then, at 3:00 a.m., I found a resistor that tested OK out of the circuit but was apparently shorting under load. That fixed the oscillator grid.
The culprit:
Winky Dink
Damn the patina,
Full speed ahead!
Old 02-06-2014, 01:18 PM
Winky Dink's Avatar
Holy Porosity, Batman!
Curiosity overcame me this morning. The few carbon resistor failures that I've seen looked burned. Why would this normal-looking resistor fail? I assume this porosity wasn't part of the design, but was it a manufacturing defect or did it occur during use?
In that vein, here's a photo of something I found a few months ago when I started this project. When checking continuity, I couldn't get consistent readings on this coil. I think somebody at the factory forgot to solder this one.
Winky Dink
Damn the patina,
Full speed ahead!
Old 02-06-2014, 01:20 PM
Reece's Avatar
Reece Reece is offline
It's all just circuit tracing. Good for you. So is the radio working OK now? You might want to go back through and look at all chassis grounds: they might look OK but have hidden corrosion that will show up later as intermittence or silence. What some do is grind a bit on the chassis right next to the grounding lug and with a heavy iron or gun get solder from the lug right over and onto the chassis.
Reece
Old 02-06-2014, 01:23 PM
Reece's Avatar
We were posting at the same time! Wow, take a pic of that unsoldered lug and send it back to the Philco factory in Philly. They'll take proper measures.
Reece
